Aller au contenu principal
iPod Touch 5th Generation Rear-Facing Camera Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: étape 1, image 1 de 3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: étape 1, image 2 de 3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: étape 1, image 3 de 3
    • Insert the flat end of a spudger between the rear-facing camera and its frame.
    • Gently twist the spudger to free the camera.
    • Lift the rear-facing camera up out of its socket, and remove it from the iPod Touch.
  2. iPod Touch 5th Generation Rear-Facing Camera Replacement: étape 2, image 1 de 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: étape 2, image 2 de 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: étape 2, image 3 de 3
    • Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable.
    • Run the spudger along the full length of the tape to disconnect it from the rear case.
  3. iPod Touch 5th Generation Rear-Facing Camera Replacement: étape 3, image 1 de 2 iPod Touch 5th Generation Rear-Facing Camera Replacement: étape 3, image 2 de 2
    • Peel and remove the foam tape from the rear case of the iPod.
  4. iPod Touch 5th Generation Rear-Facing Camera Replacement: étape 4, image 1 de 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: étape 4, image 2 de 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Use the tip of a spudger to peel up the edge of the tape covering the button ribbon cable.
    • Use tweezers or your fingers to peel the tape up from the rear case, and remove it from the iPod.
Andrew Optimus Goldheart
Membre depuis le 10/17/09
508 760 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 471 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 13
Total : 112
