Aller au contenu principal
iRobot Braava 375t Battery Replacement
Ce dont vous avez besoin
  1. iRobot Braava 375t Battery Replacement, Battery: étape 1, image 1 de 1
    • Turn the device over upside down and locate the battery panel.
    • The panel has a symbol of a trash can crossed out.
  2. iRobot Braava 375t Battery Replacement: étape 2, image 1 de 1
    • After locating the panel, locate the screw (should be around the top center).
    • You will need a medium sized flathead screwdriver to loosen the screw.
  3. iRobot Braava 375t Battery Replacement: étape 3, image 1 de 1
    • Insert the screwdriver and turn counter clockwise (left) to loosen the screw.
    • You may need to apply pressure when turning if the screw is tight.
  4. iRobot Braava 375t Battery Replacement: étape 4, image 1 de 2 iRobot Braava 375t Battery Replacement: étape 4, image 2 de 2
    • Once the screw is completely taken off, remove the panel to reveal the battery.
    • The battery will have a wire, follow the wire which will lead to a plastic white clip (pin). Pull the wire clip upwards carefully until the all pins are separated.
    • Use a small screwdriver and wedge the head between the clips if the pins are tight.
Jadealyn Paulino
Membre depuis le 09/26/22
275 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 5-5, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-5, Adachi Fall 2022
CSULA-ADACHI-F22S5G5
6 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 18
Total : 157
