Aller au contenu principal
iRobot Braava 375t Fluid Reservoir Replacement
  1. iRobot Braava 375t Fluid Reservoir Replacement, Fluid Reservoir: étape 1, image 1 de 2 iRobot Braava 375t Fluid Reservoir Replacement, Fluid Reservoir: étape 1, image 2 de 2
    • Begin by removing the fluid reservoir from the vacuum. To remove, lift upwards from the two buttons on each side.
  2. iRobot Braava 375t Fluid Reservoir Replacement: étape 2, image 1 de 2 iRobot Braava 375t Fluid Reservoir Replacement: étape 2, image 2 de 2
    • After removing the fluid reservoir from the device, turn the reservoir upside down and take off the cleaning cloth attached to the velcro strips.
  3. iRobot Braava 375t Fluid Reservoir Replacement: étape 3, image 1 de 1
    • Inspect the blue cap that is used to insert the cleaning solution. Determine if the rubber is damaged (holes, tears, etc.). Next, check the surrounding plastic area for cracks or deep scratches.
    • To temporarily fix cracks in the surrounding plastic area, apply a sealant like gorilla glue around the inlet of the blue cap. However, it's best to replace the whole reservoir to prevent further damage.
    • If damaged in any way, you can purchase a new reservoir from the iRobot website or similar sites such as Amazon or eBay.
Diego
Membre depuis le 09/26/22
235 Réputation
2 tutoriels rédigés
Équipe
CSU Los Angeles, Team 5-5, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-5, Adachi Fall 2022
CSULA-ADACHI-F22S5G5
6 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 17
Total : 127
