Introduction
The fluid reservoir in the iRobot Braava 375T is a compartment filled with the cleaning solutions used in cleaning hard surfaces. If fluid is leaking from the component, or an excess amount of liquid is coming out of the device, then the fluid reservoir may need to be replaced. This guide will cover the steps to replace the fluid reservoir in the iRobot Braava 375T.
Begin by removing the fluid reservoir from the vacuum. To remove, lift upwards from the two buttons on each side.
