Introduction
Replace a damaged or worn out Roomba discovery (4210) battery.
Ce dont vous avez besoin
Make sure Roomba is powered off.
make sure Roomba is unplugged
If your battery is bad Powering off Roomba shouldn't be a problem.
Depress side clips and lift up.
you may need to use moderate force to remove the battery.
The battery is now removed.
The battery slot is where the serial number is located
Slide new battery Into the slot.
make sure that the clips snap into place on BOTH sides.
flip over Roomba.
Put Roomba on charge for 16 hours then run on MAX cycle to condition the battery.
Remember to condition your battery
