Aller au contenu principal
iRobot Roomba 551 Bumper Sensor Replacement
Ce dont vous avez besoin
  1. iRobot Roomba 551 Bumper Sensor Replacement, Side Brush: étape 1, image 1 de 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Bumper Sensor Replacement: étape 2, image 1 de 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Bumper Sensor Replacement: étape 3, image 1 de 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Bumper Sensor Replacement, Bottom Plate: étape 4, image 1 de 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Bumper Sensor Replacement: étape 5, image 1 de 2 iRobot Roomba 551 Bumper Sensor Replacement: étape 5, image 2 de 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Bumper Sensor Replacement: étape 6, image 1 de 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Bumper Sensor Replacement, Bumper: étape 7, image 1 de 3 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: étape 7, image 2 de 3 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: étape 7, image 3 de 3
    • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
  8. iRobot Roomba 551 Bumper Sensor Replacement: étape 8, image 1 de 1
    • Lift the bottom cover and set it to the side.
  9. iRobot Roomba 551 Bumper Sensor Replacement: étape 9, image 1 de 2 iRobot Roomba 551 Bumper Sensor Replacement: étape 9, image 2 de 2
    • Flip the Roomba over, grasp the bumper, and gently lift to remove.
    • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
  10. iRobot Roomba 551 Bumper Sensor Replacement, Bumper Sensor: étape 10, image 1 de 1
    • Flip the Roomba so that the bottom is facing you.
  11. iRobot Roomba 551 Bumper Sensor Replacement: étape 11, image 1 de 2 iRobot Roomba 551 Bumper Sensor Replacement: étape 11, image 2 de 2
    • Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
  12. iRobot Roomba 551 Bumper Sensor Replacement: étape 12, image 1 de 1
    • Pull gently on the bottom of the sensor to remove.
  13. iRobot Roomba 551 Bumper Sensor Replacement: étape 13, image 1 de 3 iRobot Roomba 551 Bumper Sensor Replacement: étape 13, image 2 de 3 iRobot Roomba 551 Bumper Sensor Replacement: étape 13, image 3 de 3
    • Flip the bumper over and lift the sensor from its compartment.
    • You are now free to replace the bumper sensor.
4 autres ont terminé cette réparation.
Cody Rhoads
Membre depuis le 01/16/14
348 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-14, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 membres
19 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 4,679
