Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iRobot Roomba 551 Bumper Sensor Replacement
Ce dont vous avez besoin
    1. iRobot Roomba 551 Bumper Sensor Replacement, Side Brush: étape 1, image 1 de 1
      • Place your Roomba upside-down on a hard surface.
      Demander à FixBot
      Ajouter un commentaire
    2. iRobot Roomba 551 Bumper Sensor Replacement: étape 2, image 1 de 1
      • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
      Demander à FixBot
    3. iRobot Roomba 551 Bumper Sensor Replacement: étape 3, image 1 de 1
      • Gently pull upwards on the brush to remove it.
      Demander à FixBot
    1. iRobot Roomba 551 Bumper Sensor Replacement, Bottom Plate: étape 4, image 1 de 1
      • Rotate the Roomba upside-down so the bottom is facing towards you.
      Demander à FixBot
    2. iRobot Roomba 551 Bumper Sensor Replacement: étape 5, image 1 de 2 iRobot Roomba 551 Bumper Sensor Replacement: étape 5, image 2 de 2
      • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
      Demander à FixBot
    3. iRobot Roomba 551 Bumper Sensor Replacement: étape 6, image 1 de 1
      • Carefully lift the bottom plate.
      • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
      Demander à FixBot
    1. iRobot Roomba 551 Bumper Sensor Replacement, Bumper: étape 7, image 1 de 3 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: étape 7, image 2 de 3 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: étape 7, image 3 de 3
      • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
      Demander à FixBot
    2. iRobot Roomba 551 Bumper Sensor Replacement: étape 8, image 1 de 1
      • Lift the bottom cover and set it to the side.
      Demander à FixBot
    3. iRobot Roomba 551 Bumper Sensor Replacement: étape 9, image 1 de 2 iRobot Roomba 551 Bumper Sensor Replacement: étape 9, image 2 de 2
      • Flip the Roomba over, grasp the bumper, and gently lift to remove.
      • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
      Demander à FixBot
    1. iRobot Roomba 551 Bumper Sensor Replacement, Bumper Sensor: étape 10, image 1 de 1
      • Flip the Roomba so that the bottom is facing you.
      Demander à FixBot
    2. iRobot Roomba 551 Bumper Sensor Replacement: étape 11, image 1 de 2 iRobot Roomba 551 Bumper Sensor Replacement: étape 11, image 2 de 2
      • Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
      Demander à FixBot
    3. iRobot Roomba 551 Bumper Sensor Replacement: étape 12, image 1 de 1
      • Pull gently on the bottom of the sensor to remove.
      Demander à FixBot
    4. iRobot Roomba 551 Bumper Sensor Replacement: étape 13, image 1 de 3 iRobot Roomba 551 Bumper Sensor Replacement: étape 13, image 2 de 3 iRobot Roomba 551 Bumper Sensor Replacement: étape 13, image 3 de 3
      • Flip the bumper over and lift the sensor from its compartment.
      • You are now free to replace the bumper sensor.
      Demander à FixBot
4 autres ont terminé cette réparation.
Cody Rhoads
Membre depuis le 01/16/14
348 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-14, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 membres
32 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 23
Total : 5,013
