Introduction
This guide explains how to remove the faceplate from your Roomba.
Pièces
Aucune pièce nécessaire.
  1. Place your Roomba upside-down on a hard surface.
    • Place your Roomba upside-down on a hard surface.
  2. While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Gently pull upwards on the brush to remove it.
    • Gently pull upwards on the brush to remove it.
  4. Rotate the Roomba upside-down so the bottom is facing towards you.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  7. Carefully lift the bottom plate.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  8. Push on the dirt bin release button, and pull gently.
    • Push on the dirt bin release button, and pull gently.
  9. With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper. With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper. With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
    • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
  10. Lift the bottom cover and set it to the side.
    • Lift the bottom cover and set it to the side.
  11. Flip the Roomba over, grasp the bumper, and gently lift to remove. The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
    • Flip the Roomba over, grasp the bumper, and gently lift to remove.
    • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
  12. Pull up on the front of the faceplate until the friction locks pop out of place. Pull up on the front of the faceplate until the friction locks pop out of place. Pull up on the front of the faceplate until the friction locks pop out of place.
    • Pull up on the front of the faceplate until the friction locks pop out of place.
  13. Continue around the outside of the Roomba, pulling up on the faceplate to free all of the outer friction locks. Continue around the outside of the Roomba, pulling up on the faceplate to free all of the outer friction locks.
    • Continue around the outside of the Roomba, pulling up on the faceplate to free all of the outer friction locks.
  14. Grab the faceplate by the outer edge and pull upwards, freeing the center friction locks in the process. Grab the faceplate by the outer edge and pull upwards, freeing the center friction locks in the process.
    • Grab the faceplate by the outer edge and pull upwards, freeing the center friction locks in the process.
Aaron Jacobs
Membre depuis le 31/01/2014
525 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-14, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 membres
13 tutoriels rédigés
If all you need off is the faceplate, you can start at step 11 and skip the 1-10. The bottom and bumper assemblies seem completely unrelated to the faceplate. I removed the dirt bin and started lifiting at the back edge, then worked around the faceplate and it just popped off with no damage.
There are 4 long friction tabs around the circumference, and no tabs at the center. Once the outer friction tabs are free, the center circle of the faceplate comes off cleanly, leaving the display panel, control buttons and the chrome-ish ring. Under the 'IR' in the IRobot logo on the faceplate is the SCI port, more plastic and a number of screws to get to the motherboard.
David Forrest - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 682
