Aller au contenu principal
iRobot Roomba 595 Pet Series Side Brush Motor Replacement
Ce dont vous avez besoin
  1. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Secondary Brush: étape 1, image 1 de 1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: étape 2, image 1 de 1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: étape 3, image 1 de 2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: étape 3, image 2 de 2
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Lift the external underside cover accordingly.
  4. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: étape 4, image 1 de 1
    • Use the Phillips #0 screwdriver bit to remove the three 15mm screws.
  5. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: étape 5, image 1 de 2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: étape 5, image 2 de 2
    • Remove the motor from the blue casing.
Dale Shirley-Potopsingh
Membre depuis le 10/02/17
446 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S10-G5, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
3 membres
5 tutoriels rédigés
2 commentaires
I changed the motor and still does not work.
Jose - Réponse
I changed the motor and still did not work.
Jose - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 710
