Aller au contenu principal
iRobot Roomba 630 Side Brush Motor Replacement
Ce dont vous avez besoin
  1. iRobot Roomba 630 Side Brush Motor Replacement, Side Brush Motor: étape 1, image 1 de 2 iRobot Roomba 630 Side Brush Motor Replacement, Side Brush Motor: étape 1, image 2 de 2
    • Flip the Roomba over so that the wheels are facing upwards.
    • Unscrew the 6 mm screw from the yellow side brush using a Phillips #2 screwdriver.
  2. iRobot Roomba 630 Side Brush Motor Replacement: étape 2, image 1 de 2 iRobot Roomba 630 Side Brush Motor Replacement: étape 2, image 2 de 2
    • Remove the four 10.1 mm screws from the back cover using a Phillips #2 screwdriver.
    • Lift the back cover off to access the gear box.
  3. iRobot Roomba 630 Side Brush Motor Replacement: étape 3, image 1 de 3 iRobot Roomba 630 Side Brush Motor Replacement: étape 3, image 2 de 3 iRobot Roomba 630 Side Brush Motor Replacement: étape 3, image 3 de 3
    • Remove the three outer 15 mm screws that hold down the gearbox using a Phillips #2 screwdriver.
    • Remove the middle 15 mm screw to release the gearbox using a tri-point Y0 screwdriver.
    • Lift the blue side brush gear box out.
  4. iRobot Roomba 630 Side Brush Motor Replacement: étape 4, image 1 de 2 iRobot Roomba 630 Side Brush Motor Replacement: étape 4, image 2 de 2
    • Pry the top of the gear box off.
    • Check for debris in the gear box and clean it out if needed.
  5. iRobot Roomba 630 Side Brush Motor Replacement: étape 5, image 1 de 3 iRobot Roomba 630 Side Brush Motor Replacement: étape 5, image 2 de 3 iRobot Roomba 630 Side Brush Motor Replacement: étape 5, image 3 de 3
    • Remove the screws holding the motor in place using a Phillips #2 screwdriver.
    • Pull the old motor out.
4 autres ont terminé cette réparation.
Jabari Baptiste
Membre depuis le 10/03/17
485 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S5-G3, Walkup Fall 2017 Membre de l'équipe USF Tampa, Team S5-G3, Walkup Fall 2017
USFT-WALKUP-F17S5G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 32
Total : 2,073
