Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iRobot Roomba 655 Pet Series Internal Faceplate Removal
Ce dont vous avez besoin
    1. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Face Plate: étape 1, image 1 de 2 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Face Plate: étape 1, image 2 de 2
      • Remove the dust bin by pushing on the button for the dust bin removal
      • Pull the dust bin out
      Demander à FixBot
      Ajouter un commentaire
    2. iRobot Roomba 655 Pet Series Internal Faceplate Removal: étape 2, image 1 de 2 iRobot Roomba 655 Pet Series Internal Faceplate Removal: étape 2, image 2 de 2
      • Pull up on the silver handle to release the top protectant plastic
      • Remove the top plastic carefully
      Demander à FixBot
    1. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Bumper: étape 3, image 1 de 2 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Bumper: étape 3, image 2 de 2
      • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
      • Pull the plastic bumper protector up and off of the bumper.
      Demander à FixBot
    2. iRobot Roomba 655 Pet Series Internal Faceplate Removal: étape 4, image 1 de 3 iRobot Roomba 655 Pet Series Internal Faceplate Removal: étape 4, image 2 de 3 iRobot Roomba 655 Pet Series Internal Faceplate Removal: étape 4, image 3 de 3
      • Flip the Roomba back over, so you are viewing the top.
      • Pull up on the front bumper to remove it.
      • Be careful not to pull too hard because there is wiring attached to the bumper.
      • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
      Demander à FixBot
    1. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: étape 5, image 1 de 3 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: étape 5, image 2 de 3 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: étape 5, image 3 de 3
      • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
      • Use your Phillips head #0 to remove the one - 7mm bottom center screw
      • Use your Phillips head #2 to remove the two - 8mm screws by the handle
      • Push down the two release points to pull the plastic piece up
      • Pull the plastic piece up
      Demander à FixBot
Rhett
Membre depuis le 01/22/15
1 350 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 21-20, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 membres
29 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 30
Total : 1,204
