Aller au contenu principal
iRobot Roomba 770 Brush Replacement
  1. iRobot Roomba 770 Brush Replacement, Brush: étape 1, image 1 de 1
    • Orient the roomba so it is upside down and the dust tray is closest to you.
  2. iRobot Roomba 770 Brush Replacement: étape 2, image 1 de 2 iRobot Roomba 770 Brush Replacement: étape 2, image 2 de 2
    • Locate the two yellow tabs on the screen that covers the brushes.
    • Push inwards on the yellow tabs while simultaneously pulling upwards on the attached grey cage.
  3. iRobot Roomba 770 Brush Replacement: étape 3, image 1 de 3 iRobot Roomba 770 Brush Replacement: étape 3, image 2 de 3 iRobot Roomba 770 Brush Replacement: étape 3, image 3 de 3
    • Grab the right side of the larger brush that is located near the yellow cap. Pull upwards and to the right to remove the brush.
    • Repeat the same steps with the smaller brush.
  4. iRobot Roomba 770 Brush Replacement: étape 4, image 1 de 2 iRobot Roomba 770 Brush Replacement: étape 4, image 2 de 2
    • Orient the brush so the yellow tab is on the right hand side.
    • Pull the yellow tab to the right to remove.
    • Remove any debris, paying attention to the ends as well as the brush itself.
    • Replace any damaged brushes.
Andrew Horvath
Membre depuis le 10/05/16
444 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 15-3, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 15-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G3
3 membres
5 tutoriels rédigés
Un commentaire
My roomba starts and moves a foot or so and then stops. I have cleaned it entirely, the battery is fine and the wheels are clean. Anyone have a suggestion
Mary Ann Dyer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 11
Total : 2,334
