Aller au contenu principal
iRobot Roomba 870 Bumper Sensor Replacement
Ce dont vous avez besoin
  1. iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: étape 1, image 1 de 2 iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: étape 1, image 2 de 2
    • Flip the iRoomba over so that the underside is facing up.
    • Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
    • Remove the yellow side brush.
  2. iRobot Roomba 870  Bumper Sensor Replacement: étape 2, image 1 de 3 iRobot Roomba 870  Bumper Sensor Replacement: étape 2, image 2 de 3 iRobot Roomba 870  Bumper Sensor Replacement: étape 2, image 3 de 3
    • Remove the two 3.5 mm Phillips screws that hold the battery cover onto the Roomba with a Phillips #0 screwdriver.
    • Remove the battery cover.
  3. iRobot Roomba 870  Bumper Sensor Replacement: étape 3, image 1 de 3 iRobot Roomba 870  Bumper Sensor Replacement: étape 3, image 2 de 3 iRobot Roomba 870  Bumper Sensor Replacement: étape 3, image 3 de 3
    • Remove the two remaining 3.5 mm Phillips #0 screws that attach the base-plate to the bottom of the Roomba.
    • Remove the entire base-plate from the bottom of the Roomba.
  4. iRobot Roomba 870  Bumper Sensor Replacement: étape 4, image 1 de 3 iRobot Roomba 870  Bumper Sensor Replacement: étape 4, image 2 de 3 iRobot Roomba 870  Bumper Sensor Replacement: étape 4, image 3 de 3
    • Remove the ten 3 mm screws that attach the bumper guard to the bumper with a Phillips #1 screwdriver.
    • Remove the bumper guard.
  5. iRobot Roomba 870  Bumper Sensor Replacement: étape 5, image 1 de 2 iRobot Roomba 870  Bumper Sensor Replacement: étape 5, image 2 de 2
    • Be careful when removing the bumper from the Roomba to prevent damage to the sensor wires. Remove slowly!
    • Lift up the Roomba so that its bumper is not resting on anything, and slowly separate the bumper from the device.
  6. iRobot Roomba 870  Bumper Sensor Replacement: étape 6, image 1 de 3 iRobot Roomba 870  Bumper Sensor Replacement: étape 6, image 2 de 3 iRobot Roomba 870  Bumper Sensor Replacement: étape 6, image 3 de 3
    • Remove the two 3 mm screws that attach the sensor connector to the bumper/sensor with a #1 Phillips Screwdriver.
    • Carefully detach the sensor connector from the bumper and the sensor.
  7. iRobot Roomba 870  Bumper Sensor Replacement: étape 7, image 1 de 2 iRobot Roomba 870  Bumper Sensor Replacement: étape 7, image 2 de 2
    • The sensor is now loose on the bumper. Be careful not to rapidly move the bumper for fear of dislodging the sensor and breaking it.
    • Flip the bumper over, ensuring the sensor remains inside the sensor compartment.
    • Gently remove the bumper from the black infrared sensor.
13 autres ont terminé cette réparation.
Jacob Lindberg
Membre depuis le 04/19/17
449 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S14-G3, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
4 membres
10 tutoriels rédigés
3 commentaires de tutoriel
Can not get to the plug-in area on the board to replace sensor this way. DOES NOT work this way.
jkeysgate - Réponse
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
Reinhard Totzauer - Réponse
Incomplete. This NEEDs to explain how to access the plug on the board.
Ed T. - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 33
Total : 8,746
