Aller au contenu principal
iRobot Roomba 870 Battery Replacement
Ce dont vous avez besoin
  1. iRobot Roomba 870 Battery Replacement, Battery: étape 1, image 1 de 2 iRobot Roomba 870 Battery Replacement, Battery: étape 1, image 2 de 2
    • To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
    • Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
    • Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
  2. iRobot Roomba 870 Battery Replacement: étape 2, image 1 de 3 iRobot Roomba 870 Battery Replacement: étape 2, image 2 de 3 iRobot Roomba 870 Battery Replacement: étape 2, image 3 de 3
    • Remove the loose battery cover to access the battery compartment.
    • Use the yellow tabs, located on the short ends of the battery pack, to gently pull the battery up and out of its slot.
Follow the steps in reverse order for reassembly.
2 autres ont terminé cette réparation.
Vitek Harvey
Membre depuis le 04/26/17
149 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S14-G3, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 28
Total : 3,376
