Introduction
This guide will show you how to replace the whole Cleaning Head in the Roomba 880, which houses the Debris Extractors. Let's do it!
Ce dont vous avez besoin
Flip the Roomba over, wheel-side up.
Using a Phillips #1 screwdriver, loosen the four 15 mm screws illustrated. Two are located on the battery door, while two are on the bottom panel.
Remove the battery door, pulling straight up from the two indents above the screws.
Using a flat head screwdriver, loosen the screw on the top of the side brush.
Remove side brush.
Reach underneath the dust bin, press the bin removal button, and pull out.
Remove the cleaning head by grabbing the two protruding tabs as shown, and pulling straight up.
