Aller au contenu principal
iRobot Roomba 890 IR Sensor Replacement
Ce dont vous avez besoin
  1. iRobot Roomba 890 IR Sensor Replacement, IR sensor: étape 1, image 1 de 1
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
    • Remove the battery cover.
  2. iRobot Roomba 890 IR Sensor Replacement: étape 2, image 1 de 2 iRobot Roomba 890 IR Sensor Replacement: étape 2, image 2 de 2
    • Pull directly up on the grey pull-tabs to remove the battery.
  3. iRobot Roomba 890 IR Sensor Replacement: étape 3, image 1 de 1
    • Use a Phillips #2 screwdriver to remove the one 7.7 mm screw.
    • Remove the yellow brush head.
  4. iRobot Roomba 890 IR Sensor Replacement: étape 4, image 1 de 3 iRobot Roomba 890 IR Sensor Replacement: étape 4, image 2 de 3 iRobot Roomba 890 IR Sensor Replacement: étape 4, image 3 de 3
    • Use a Phillips #2 screwdriver to unscrew the two 11 mm screws.
    • Lift the baseplate up and off.
  5. iRobot Roomba 890 IR Sensor Replacement: étape 5, image 1 de 2 iRobot Roomba 890 IR Sensor Replacement: étape 5, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the ten 9.3 mm screws.
    • Remove the bumper retainer ring.
  6. iRobot Roomba 890 IR Sensor Replacement: étape 6, image 1 de 2 iRobot Roomba 890 IR Sensor Replacement: étape 6, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the two 7.5 mm screws holding the IR sensor in place.
  7. iRobot Roomba 890 IR Sensor Replacement: étape 7, image 1 de 2 iRobot Roomba 890 IR Sensor Replacement: étape 7, image 2 de 2
    • Use an iFixit opening tool to remove the outer plastic covering from the top of the Roomba.
  8. iRobot Roomba 890 IR Sensor Replacement: étape 8, image 1 de 3 iRobot Roomba 890 IR Sensor Replacement: étape 8, image 2 de 3 iRobot Roomba 890 IR Sensor Replacement: étape 8, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handlebar screws; then remove the handle.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift off the top plate.
  9. iRobot Roomba 890 IR Sensor Replacement: étape 9, image 1 de 3 iRobot Roomba 890 IR Sensor Replacement: étape 9, image 2 de 3 iRobot Roomba 890 IR Sensor Replacement: étape 9, image 3 de 3
    Outil utilisé dans cette étape :
    $3.99
    • Use a pair of angled tweezers to firmly grip the IR sensor plug, and pull it directly backwards to release it from the motherboard.
Caeden Foxhoven
Membre depuis le 03/28/22
331 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-3, Petersen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-3, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G3
3 membres
14 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 25
Total : 1,319
