Aller au contenu principal
iRobot Roomba 890 Motorized Wheel Module Replacement
Ce dont vous avez besoin
  1. iRobot Roomba 890 Motorized Wheel Module Replacement, Motorized Wheel Module: étape 1, image 1 de 2 iRobot Roomba 890 Motorized Wheel Module Replacement, Motorized Wheel Module: étape 1, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw securing the side brush-head.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Motorized Wheel Module Replacement: étape 2, image 1 de 1
    • Place the Roomba with its bottom facing toward you.
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
  3. iRobot Roomba 890 Motorized Wheel Module Replacement: étape 3, image 1 de 2 iRobot Roomba 890 Motorized Wheel Module Replacement: étape 3, image 2 de 2
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Motorized Wheel Module Replacement: étape 4, image 1 de 1
    • Lift off the baseplate.
  5. iRobot Roomba 890 Motorized Wheel Module Replacement: étape 5, image 1 de 2 iRobot Roomba 890 Motorized Wheel Module Replacement: étape 5, image 2 de 2
    • Remove the collection bin by pressing the release button on the top side of the Roomba and pulling straight out.
  6. iRobot Roomba 890 Motorized Wheel Module Replacement: étape 6, image 1 de 2 iRobot Roomba 890 Motorized Wheel Module Replacement: étape 6, image 2 de 2
    • On the underside of the Roomba, use a Phillips #1 screwdriver to remove the three 15.5 mm screws.
  7. iRobot Roomba 890 Motorized Wheel Module Replacement: étape 7, image 1 de 1
    • Grip both sides of the casing and pull it straight out.
Dustin Staples
Membre depuis le 03/28/22
339 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-3, Petersen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-3, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G3
3 membres
14 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 43
Total : 820
