Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iRobot Roomba 960 Filter Replacement
Ce dont vous avez besoin
    1. iRobot Roomba 960 Filter Replacement, Filter: étape 1, image 1 de 1
      • Orient the Roomba so that the device is on its wheels and the words can be read from left to right.
      Demander à FixBot
      Ajouter un commentaire
    2. iRobot Roomba 960 Filter Replacement: étape 2, image 1 de 3 iRobot Roomba 960 Filter Replacement: étape 2, image 2 de 3 iRobot Roomba 960 Filter Replacement: étape 2, image 3 de 3
      • Press the large button on the Roomba that is located closest to you.
      • Pull to remove the dust bin.
      Demander à FixBot
    3. iRobot Roomba 960 Filter Replacement: étape 3, image 1 de 3 iRobot Roomba 960 Filter Replacement: étape 3, image 2 de 3 iRobot Roomba 960 Filter Replacement: étape 3, image 3 de 3
      • With the dust bin completely detached from the Roomba, press the tab that is located on your right (there is a yellow arrow pointing to it).
      • Lift the red plastic cover to access the filter.
      Demander à FixBot
    4. iRobot Roomba 960 Filter Replacement: étape 4, image 1 de 3 iRobot Roomba 960 Filter Replacement: étape 4, image 2 de 3 iRobot Roomba 960 Filter Replacement: étape 4, image 3 de 3
      • Using the yellow ribbon that is located at the top of the filter, pull it towards you.
      • Carefully remove the used filter.
      Demander à FixBot
Vanessa Greyson
Membre depuis le 02/02/17
471 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 16-3, Blackwell Spring 2017 Membre de l'équipe USF Tampa, Team 16-3, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G3
4 membres
12 tutoriels rédigés
1 commentaire de tutoriel
I need to replace the red bin cover over the filter, do I need to unscrew the black piece or something or just try to pry it out. I don’t want to break it.
Sandra Freed - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 50
Total : 2,597
