Aller au contenu principal
iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement
  1. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement, Home Base Vacuum Bag: étape 1, image 1 de 1
    • Open the vacuum bag container at the top of the home base.
  2. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: étape 2, image 1 de 3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: étape 2, image 2 de 3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: étape 2, image 3 de 3
    • Grab the grey tab at the top of the bag and lift the bag straight out of the home base.
Charles D'Amico
Membre depuis le 01/23/20
223 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S18-G3, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G3, White Winter 2020
CPSU-WHITE-W20S18G3
4 membres
9 tutoriels rédigés
2 commentaires
what do you do if after you change the bag , the base says there is no bag? So I replaced the old bag after I pulled stuff out , still no change. now robot won’t work . On app it says end job stuck and all it did is move off base and turn around (after hit clean) help
shelleyandboys - Réponse
Can we have a tear down of the base? The bag switch sometimes doesn't want to work properly. You can resolder a new switch or just solder a jumper so it always "senses" one. There's alot of screws, sensors, wires and a big motor. It helps to know where all the screws go.
ashimo0463 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 29
Total : 1,373
