Aller au contenu principal
iRobot Roomba e5 Maintenance
Ce dont vous avez besoin
  1. iRobot Roomba e5 Maintenance, Two middle brushes, Edge Sweeping Brush and Dust Bin: étape 1, image 1 de 3 iRobot Roomba e5 Maintenance, Two middle brushes, Edge Sweeping Brush and Dust Bin: étape 1, image 2 de 3 iRobot Roomba e5 Maintenance, Two middle brushes, Edge Sweeping Brush and Dust Bin: étape 1, image 3 de 3
    • To remove the edge sweeping brush, use a Phillips #0 screwdriver to remove the 8 mm screw holding it in place.
  2. iRobot Roomba e5 Maintenance: étape 2, image 1 de 3 iRobot Roomba e5 Maintenance: étape 2, image 2 de 3 iRobot Roomba e5 Maintenance: étape 2, image 3 de 3
    • To remove the two multi-surface brushes, lift the adjacent piece by pressing down the green lever and pulling it up.
    • Then remove the brushes by lifting them by the right side.
  3. iRobot Roomba e5 Maintenance: étape 3, image 1 de 1
    • To remove the dust bin, press down on the button with a “trash bin” drawing by the side of the vacuum.
    • While pressing the button, gently pull the dust bin out.
    • When removing the dust bin, dust can tip over the surface and create a mess.
  4. iRobot Roomba e5 Maintenance: étape 4, image 1 de 2 iRobot Roomba e5 Maintenance: étape 4, image 2 de 2
    • To remove the filter located at the right side of the dust bin, press the filter on top and at the bottom and pull.
  5. iRobot Roomba e5 Maintenance: étape 5, image 1 de 3 iRobot Roomba e5 Maintenance: étape 5, image 2 de 3 iRobot Roomba e5 Maintenance: étape 5, image 3 de 3
    • Clean every part of the vacuum thoroughly with a dust rag or paper towel and Q-tip.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 38
Total : 1,150
