Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iRobot Roomba i6 Battery Replacement
Ce dont vous avez besoin
  1. iRobot Roomba i6 Battery Replacement, Remove the Bottom Cover: étape 1, image 1 de 3 iRobot Roomba i6 Battery Replacement, Remove the Bottom Cover: étape 1, image 2 de 3 iRobot Roomba i6 Battery Replacement, Remove the Bottom Cover: étape 1, image 3 de 3
    • Using your PH2 size screwdriver, remove the edge sweeping brush.
    • Using your PH2 size screwdriver, remove the 5 screws highlighted in the 2nd picture.
    • These top two screws highlighted in orange will unscrew completely if you keep going so be sure to stop unscrewing them as soon as you feel resistance.
    • Lift the bottom cover straight up off of the Roomba from the two spots the arrows are pointing to.
    Demander à FixBot
    Ajouter un commentaire
  2. iRobot Roomba i6 Battery Replacement, Remove the Battery: étape 2, image 1 de 1
    • Push the highlighted tab up while lifting the battery out of the Roomba.
    • During re-assembly, you just have to align the battery and push down until the tab clicks.
    Demander à FixBot
To install the new battery, follow these instructions in reverse order.
Kaden Gonzalez
Membre depuis le 08/16/24
314 Réputation
3 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 47
Total : 506
