Remove the four exterior screws located under controller and on the handle.
  • Remove the four exterior screws located under controller and on the handle.
  • Remove the five screw shown, and then carefully remove top plate. Electrical components are attached to top plate.
Ajouter un commentaire
Disconnect circuit board from power leads, and install new circuit board.
  • Disconnect circuit board from power leads, and install new circuit board.
  • Remove the four exterior screws to gain access to inner components. These screws are located on the bottom of the controller and on the handle.
  • Remove the five inner screws to access the Buttons
  • Remove top plate carefully so that none of the electrical components are damaged.
  • Remove broken button and insert new button into the mounting holes.
Lucas Otto
Membre depuis le 12/11/2014
101 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Membre de l'équipe UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 100
