Introduction
Is your camera not functioning correctly? Use this guide to replace the camera module in your device.
Pièces
Aucune pièce nécessaire.
Before disassembling your tablet, make sure it is powered off.
  • Before disassembling your tablet, make sure it is powered off.
  • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
Ajouter un commentaire
The camera module is located directly under the top right corner of the back cover.
  • The camera module is located directly under the top right corner of the back cover.
  • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
    • As you peel the tape backward, the front facing camera may come out, this is not an issue.
  • If the front facing camera does not come out, gently lift it out with a pair of tweezers
  • Use a spudger to lift flap on top of the camera ZIF adapter.
  • At this point the camera module can be easily removed with a pair of tweezers.
  • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
Robert Clark
Membre depuis le 21/01/2015
963 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 5-4, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 123
