The case easily comes apart as it just snaps together with no screws
Once the case is apart the PCB just lifts right out of its plastic tray
Its kind of hard to see but on the back of the PCB there's a Texas Instruments LM2901 Quad Differential Comparator
Here we see a pair of Atmel ATA6561 CAN Interface IC's. these are what communicate with the vehicles CAN bus.
In the middle we have a MAXIM 9776E that i cant find any info on
To the left theres a Texas Instruments TLV274I 3 MHz 4 channel rail to rail op amp
EDIT: After realizing i had a typo in the name, calling it an 9779E instread of the 9776E, its a 1.5W audio amp. this is used for vehicles where when using the RR you keep the original warning and door chimes but connecting a small speaker somewhere, usually shoved into the dash board.
