Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
  • Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
Ajouter un commentaire
Remove the battery cover by gently pushing inward on the arrow on the cover.
  • Remove the battery cover by gently pushing inward on the arrow on the cover.
  • While maintaining pressure push the cover upward.
  • Remove the Battery from the socket
  • When installing the battery take note of the signs displayed in the socket to determine which direction the negative and positive ends should be.
  • The SD Card slot is located under the battery case indicated here.
  • The SD Card Slides into the slot as depicted in the photo and on the indicator above the slot.
  • The ilo 1Gb Mp3 Player was only designed to accept SD Cards of 512mb or lower.
tjkurt01
Membre depuis le 04/06/2013
306 Réputation
3 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 265
