Ce dont vous avez besoin
First ensure your laptop is turned off and check if you have the necessary tools
Be careful to don't touch if not necessary any electrical part of the product and insure you're properly grounding.
Gently remove the battery.
CAUTION!!
Some products may have this battery fixed with double-sided adhesive tape. In these cases, use a wide spatula to remove the battery without bending it.
SAFETY WARNING!
Never bend or puncture the battery. Danger of explosion. If you detect a swollen or damaged battery, handle it with extreme care and place it in a protective container.
After remove the battery, you need to remove the black mylar that covers keyboard connector.
Under the I/O board there's a hole that you need to insert a tool and push the keyboard at the same time you pull the plastic as show in the picture. This plastic holds the keyboard.
There are more holders, but you just need to open one, the others will sag when you pull the keyboard smoothly
