Aller au contenu principal
ring Indoor Cam Camera Replacement
Ce dont vous avez besoin
  1. ring Indoor Cam Camera Replacement, Body: étape 1, image 1 de 3 ring Indoor Cam Camera Replacement, Body: étape 1, image 2 de 3 ring Indoor Cam Camera Replacement, Body: étape 1, image 3 de 3
    • Place the cam with the base facing towards you.
    • Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
    • Remove the base from the rest of the camera.
  2. ring Indoor Cam Camera Replacement: étape 2, image 1 de 2 ring Indoor Cam Camera Replacement: étape 2, image 2 de 2
    • Place the cam with the top facing toward you.
    • Insert the iFixit opening pick into the crease at the top of the camera.
    • Slide the pick along the crease until you can separate the top cover of the camera from the backing.
    • Leave the pick in the crease.
  3. ring Indoor Cam Camera Replacement: étape 3, image 1 de 2 ring Indoor Cam Camera Replacement: étape 3, image 2 de 2
    • Place the camera on its side where the horizontal crease is facing you.
    • Insert another iFixit opening pick into the crease between the front and back portions of the camera.
  4. ring Indoor Cam Camera Replacement: étape 4, image 1 de 3 ring Indoor Cam Camera Replacement: étape 4, image 2 de 3 ring Indoor Cam Camera Replacement: étape 4, image 3 de 3
    • Slide the pick along the vertical crease until you can remove the back cover of the cam, using the opening tool to pry the portions apart.
    • You may hear a popping noise when you pry it open.
  5. ring Indoor Cam Camera Replacement, Motherboard: étape 5, image 1 de 3 ring Indoor Cam Camera Replacement, Motherboard: étape 5, image 2 de 3 ring Indoor Cam Camera Replacement, Motherboard: étape 5, image 3 de 3
    • Gently remove the three white leads from their sockets on the top of the motherboard.
  6. ring Indoor Cam Camera Replacement: étape 6, image 1 de 2 ring Indoor Cam Camera Replacement: étape 6, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the two 4.7 mm black screws located in the corners of the motherboard.
    • Using a Phillips #00 screwdriver, remove the two silver 5 mm screws in the center of the motherboard.
  7. ring Indoor Cam Camera Replacement: étape 7, image 1 de 3 ring Indoor Cam Camera Replacement: étape 7, image 2 de 3 ring Indoor Cam Camera Replacement: étape 7, image 3 de 3
    • Use the iFixit opening pick to pry the motherboard from the body of the camera.
  8. ring Indoor Cam Camera Replacement: étape 8, image 1 de 2 ring Indoor Cam Camera Replacement: étape 8, image 2 de 2
    • Detach the black wire connecting the motherboard to the body of the camera.
  9. ring Indoor Cam Camera Replacement, Camera: étape 9, image 1 de 3 ring Indoor Cam Camera Replacement, Camera: étape 9, image 2 de 3 ring Indoor Cam Camera Replacement, Camera: étape 9, image 3 de 3
    • Gently turn to the motherboard's backside and remove the white leads connecting the camera to the socket in the motherboard.
    • Cautiously remove the camera.
John Bray
Membre depuis le 09/12/23
411 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 34
Total : 203
