Aller au contenu principal
the Nikon Coolpix 4600 AV port Replacement
Ce dont vous avez besoin
  1. the Nikon Coolpix 4600 AV port Replacement, Front and Rear Case: étape 1, image 1 de 2 the Nikon Coolpix 4600 AV port Replacement, Front and Rear Case: étape 1, image 2 de 2
    • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. the Nikon Coolpix 4600 AV port Replacement: étape 2, image 1 de 2 the Nikon Coolpix 4600 AV port Replacement: étape 2, image 2 de 2
    • Carefully pull the front and back case apart.
    • The front case is attached to internal components and cannot be removed independently.
  3. the Nikon Coolpix 4600 AV port Replacement: étape 3, image 1 de 1
    • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
    • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
    • After disconnecting the data ribbon, you can now separate the back case from the front case.
  4. the Nikon Coolpix 4600 AV port Replacement, LCD screen: étape 4, image 1 de 1
    • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen (left side of the screen will be glued down).
    • Be careful not to push the front case too hard on the table when taking the LCD out or the lens will get stuck.
    • Insert plastic tool under the screen and gently pry up the left side of the screen until the glue seal is broken.
  5. the Nikon Coolpix 4600 AV port Replacement: étape 5, image 1 de 1
    • Locate the orange ribbon cable and two wires (red and white) attached to the motherboard.
    • Lift up on the black clamp and pull out data cable.
    • Desolder the wires from motherboard. CAUTION: Improper desoldering can result in motherboard damage. Seek help if you do not have the necessary skills.
    • The screen should now be completely free from the camera.
  6. the Nikon Coolpix 4600 AV port Replacement, Motherboard: étape 6, image 1 de 1
    • Locate and remove the four 4.25 mm screws on the motherboard using a Phillips 00 screw driver.
  7. the Nikon Coolpix 4600 AV port Replacement: étape 7, image 1 de 1
    • Remove the ribbon cable on the top right of the motherboard. To remove the cable, slide the two grey tabs, located on both sides, towards the top of the camera and gently pull the cable out.
  8. the Nikon Coolpix 4600 AV port Replacement: étape 8, image 1 de 1
    • Turning the camera to the left and tilting it up, look at the left end of the motherboard to locate the grey bracket.
    • Twist the grey bracket counter clockwise to remove it from the silver LCD bracket.
  9. the Nikon Coolpix 4600 AV port Replacement: étape 9, image 1 de 2 the Nikon Coolpix 4600 AV port Replacement: étape 9, image 2 de 2
    • Using a Phillips 00 screwdriver, remove the 4.25 mm screw on bottom left edge of the LCD bracket.
    • Lift off the LCD bracket and slip the grey bracket through the LCD bracket. The LCD bracket should now be completely removed.
  10. the Nikon Coolpix 4600 AV port Replacement: étape 10, image 1 de 2 the Nikon Coolpix 4600 AV port Replacement: étape 10, image 2 de 2
    • Desolder the wire (both black and red) from the motherboard.
    • Remove the orange ribbon cable. This is done by sliding each side of the lock bar toward the center of the camera. Gently pull on the ribbon cable to remove.
  11. the Nikon Coolpix 4600 AV port Replacement: étape 11, image 1 de 2 the Nikon Coolpix 4600 AV port Replacement: étape 11, image 2 de 2
    • Gently peel back the black tape on the bottom, middle of the motherboard. Underneath you will find a screw.
    • Remove the 4.25 mm screw with a Phillips 00 screwdriver.
  12. the Nikon Coolpix 4600 AV port Replacement: étape 12, image 1 de 1
    • Gently pull the motherboard away from the lens.
    • Flip the camera over.
    • Connecting the motherboard to the front case are seven wires.
    • Desolder the seven wires.
    • If you are only removing the motherboard as an intermediate step to get to other components, do not desolder yet, as not all wires need to be removed.
    • Be careful when desoldering the wires. If you do not know how to properly desolder a wire, seek help to prevent damage to the motherboard. Also, make sure the soldering crunches don't fall into the lens case.
  13. the Nikon Coolpix 4600 AV port Replacement, AV port: étape 13, image 1 de 1
    • The AV port is soldered directly onto the back of the motherboard
    • Desolder the connection at each corner of the AV port and remove. If you do not know how to solder, seek help to prevent damage to your camera.
Nathan Sperling
Membre depuis le 05/08/12
119 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 9-43, Regan Spring 2012 Membre de l'équipe Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,091
