Aller au contenu principal
the Nokia 6230b Camera Replacement
Ce dont vous avez besoin
  1. the Nokia 6230b Camera Replacement, Back Cover: étape 1, image 1 de 1
    • Press down the button on the back panel.
  2. the Nokia 6230b Camera Replacement: étape 2, image 1 de 2 the Nokia 6230b Camera Replacement: étape 2, image 2 de 2
    • Push the back cover upwards.
  3. the Nokia 6230b Camera Replacement: étape 3, image 1 de 2 the Nokia 6230b Camera Replacement: étape 3, image 2 de 2
    • Remove the back cover from the phone.
  4. the Nokia 6230b Camera Replacement, Front Cover: étape 4, image 1 de 1
    • Press the silver button on the top of the phone.
  5. the Nokia 6230b Camera Replacement: étape 5, image 1 de 1
    • Slide your thumbnail down the case seam to separate the rest of the case.
  6. the Nokia 6230b Camera Replacement: étape 6, image 1 de 1
    • Gently remove the case.
    • Careful! Do not bend the plastic tabs.
  7. the Nokia 6230b Camera Replacement, Motherboard: étape 7, image 1 de 2 the Nokia 6230b Camera Replacement, Motherboard: étape 7, image 2 de 2
    • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
  8. the Nokia 6230b Camera Replacement: étape 8, image 1 de 2 the Nokia 6230b Camera Replacement: étape 8, image 2 de 2
    • Remove the panel that covers the motherboard.
    • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
  9. the Nokia 6230b Camera Replacement: étape 9, image 1 de 1
    • Remove the LCD screen frame.
  10. the Nokia 6230b Camera Replacement: étape 10, image 1 de 1
    • Remove the motherboard.
  11. the Nokia 6230b Camera Replacement, Camera: étape 11, image 1 de 1
    • Locate the camera on the circuit board.
  12. the Nokia 6230b Camera Replacement: étape 12, image 1 de 1
    • Place the circuit board on a firm, static free surface (no cloth/carpet).
    • NOTE: The circled alignment notch points to the left.
  13. the Nokia 6230b Camera Replacement: étape 13, image 1 de 1
    • Pull the left holding tabs to the left.
  14. the Nokia 6230b Camera Replacement: étape 14, image 1 de 1
    • Lift out the left side of the camera.
  15. the Nokia 6230b Camera Replacement: étape 15, image 1 de 1
    • Pull the right holding tabs to the right.
  16. the Nokia 6230b Camera Replacement: étape 16, image 1 de 1
    • Pull camera off of board.
2 autres ont terminé cette réparation.
Job Jao
Membre depuis le 10/08/10
37 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-27, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-27, Regan Fall 2010
CPSU-REGAN-F10S3G27
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 3
Total : 1,908
