Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Remove the single 28 mm T10 Torx screw securing the left speaker to the rear case. Lift the left speaker up and out of the rear case. Don't try to slide the speaker out, since there is a plastic mounting pin under the top end of the speaker housing that holds it in place.
  • Remove the single 28 mm T10 Torx screw securing the left speaker to the rear case.
  • Lift the left speaker up and out of the rear case. Don't try to slide the speaker out, since there is a plastic mounting pin under the top end of the speaker housing that holds it in place.
Insérez ici votre traduction
