Aller au contenu principal
Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, Bottom screws: étape 0, image 1 de 2 Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, Bottom screws: étape 0, image 2 de 2
Bottom screws
  • Note: if the laptop you are working on is a very slightly different model it is possible that it will have a different number of screws in slightly different positions. The important thing is to note where the shorter screws come from so as to avoid inserting a longer screw in its place on reassembly.
  • Remove a 5mm screw to the left of the RAM sockets, then pull out the CD/DVD drive. (Not necessary if you are only replacing the keyboard.)
  • Remove a 5mm screw to the right and the rear of the RAM sockets.
  • If you are going to remove the hard disk, motherboard or fan, remove 4 3mm screws.
  • Remove 7 5mm screws. (There are 6 more at the rear which should be left.)
Insérez ici votre traduction
