Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 4
Étape 4
Unscrew the four 3 mm PH00 Phillips head screws located on the inside corners of the screen. Be sure to unscrew the inner screws attached to the screen and not the outer screws. Be sure to unscrew the inner screws attached to the screen and not the outer screws.
  • Unscrew the four 3 mm PH00 Phillips head screws located on the inside corners of the screen.
  • Be sure to unscrew the inner screws attached to the screen and not the outer screws.
Dévissez les quatre vis cruciformes PH00 de 3 mm situées aux coins intérieurs de l’écran.
Assurez-vous de dévisser les vis intérieures fixées à l'écran et non les vis extérieures.
