Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 12 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths: Two 1.3 mm screws
  • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
  • Two 1.3 mm screws
  • Two 2.8 mm screws
  • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  • Remove the bracket.
Dévissez les quatre vis cruciformes fixant le cache de la nappe inférieure de l'écran à la carte mère :
Deux vis de 1,3  mm
Deux vis de 2,8 mm
Retirez le cache.
[* black] Remove the fourfour Phillips screws securing the lower display cable bracket to the logic boardboard, of the following lengths:
[* red] Two 1.3 mm screws
[* orange] Two 2.8 mm screws
[* icon_reminder] Throughout this guide, [product|IF145-167-4|keep careful track of your screws] so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
[* black] Remove the bracket.
