Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Traduction de l’étape 5
Étape 5
Slide an opening pick under the antenna flex cable to hold the socket down.
Use the point of your spudger to pry up and disconnect the antenna flex cable from its socket, using the opening pick to hold the socket down.
[* black] Slide an opening pick under the antenna flex cable to hold the socket down. | |
[* black] Use the point of your spudger to pry up and disconnect the antenna flex cable from its socket, using the opening pick to hold the socket down. | |
- | [* icon_reminder] Reconnecting this cable can be tricky. Make it easier by using your tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press straight down on the connector with the flat of your spudger until it clicks into place. |
+ | [* icon_reminder] Reconnecting this cable can be tricky. Make it easier by using your [product|IF145-020|tweezers] to hold the flex cable so the connector aligns with its socket. Then, gently press straight down on the connector with the flat of your spudger until it clicks into place. |
