Aller au contenu principal
Anglais
Français
Traduction de l’étape 11
Étape 11
There are three 13mm bolts holding the water pump pulley to the water pump You can use a strap wrench to prevent the pulley from rotating You can also use a flat head screwdriver to prevent rotation
Water Pump Pulley Removal
  • There are three 13mm bolts holding the water pump pulley to the water pump
  • You can use a strap wrench to prevent the pulley from rotating
  • You can also use a flat head screwdriver to prevent rotation
  • During reassembly, snug the bolts to hand tight, install the accessory belt, then torque down the bolts
  • Gently remove the pulley
  • While it is not necessary to remove the water pump, it is a great time to change it!
Insérez ici votre traduction
