Aller au contenu principal
Anglais
Français
Traduction de l’étape 13
Étape 13
There are ten 8mm bolts holding the valve cover down These bolts must be removed from outside to inside, working diagonally
Valve Cover Removal
  • There are ten 8mm bolts holding the valve cover down
  • These bolts must be removed from outside to inside, working diagonally
  • On reassembly these bolts must be torqued in two stages, working from inside to outside
  • On the first stage, tighten to 2 Nm
  • On the second stage, tighten to 7 Nm
  • Disconnect the vacuum hose going to the intake
  • It is recommended that you change the valve cover gasket before reassembly
Insérez ici votre traduction
