Aller au contenu principal
Anglais
Français
Traduction de l’étape 15
Étape 15
Using a block of scrap wood between a hydraulic jack and the oil pan, use the jack to support the engine Do not lift the engine! Merely allow it to rest on the jack. Mark the position of the motor mount relative to the car frame with a sharpie
Motor Mount Removal
  • Using a block of scrap wood between a hydraulic jack and the oil pan, use the jack to support the engine
  • Do not lift the engine! Merely allow it to rest on the jack.
  • Mark the position of the motor mount relative to the car frame with a sharpie
  • There are three 15mm bolts holding the motor mount to the car frame.
  • During reassembly these bolts must be torqued to 48 Nm
  • There are two 18mm nuts holding the motor mount to the engine
  • It is normal for the stud to come out with these nuts
  • During reassembly these bolts must be torqued to 80 Nm
Insérez ici votre traduction
