Aller au contenu principal
Anglais
Français
Traduction de l’étape 19
Étape 19
The following steps illustrate how to align the engine to Top Dead Center (TDC) It is crucial that extra care is taken to ensure the engine is at TDC before reassembly Never rotate the engine counterclockwise.  Only rotate the engine in the direction of rotation, clockwise
Timing the Engine
  • The following steps illustrate how to align the engine to Top Dead Center (TDC)
  • It is crucial that extra care is taken to ensure the engine is at TDC before reassembly
  • Never rotate the engine counterclockwise. Only rotate the engine in the direction of rotation, clockwise
  • You will need the proper bar and pin tool to check the timing.
  • Never use the bar and pin to hold the crank or camshafts. Doing so could result in permanent engine damage
  • With the timing belt removed never rotate the crankshaft or camshafts independently of one another. Doing so could result in permanent engine damage
Insérez ici votre traduction
