Aller au contenu principal
Anglais
Français
Traduction de l’étape 21
Étape 21
Underneath the exhaust manifold there is a 13mm plug where the crankshaft stopper must be inserted.   Use a wrench to remove the stud Using the longer stopper, fully insert and screw it in until snug. This will prevent the crankshaft from moving clockwise past TDC.  With the stopper in place rotate the engine clockwise until it no longer turns.   The crankshaft will be at exactly TDC.
Crankshaft Stopper Plug
  • Underneath the exhaust manifold there is a 13mm plug where the crankshaft stopper must be inserted. Use a wrench to remove the stud
  • Using the longer stopper, fully insert and screw it in until snug.
  • This will prevent the crankshaft from moving clockwise past TDC. With the stopper in place rotate the engine clockwise until it no longer turns. The crankshaft will be at exactly TDC.
  • This will not prevent the engine from rotating counter clockwise. Never rotate the engine counterclockwise
  • Do not use the stopper to prevent engine rotation. Always restrain engine movement with a proper tools
Insérez ici votre traduction
