Aller au contenu principal
Anglais
Français
Traduction de l’étape 23
Étape 23
Due to slight variations in the the spacing between timing belt teeth, we must loosen but not remove the camshaft sprockets.   The intake sprocket bolt is hidden inside of the VCT gear, and the cover must be removed to expose it. There is a T55 Bolt holding the exhaust sprocket in place.  While holding the camshaft with a proper open end wrench, loosen but do not remove this bolt.  This will allow the camshaft sprocket to rotate. It is reccommended that you  remove the timing bar while loosening to avoid damage to the bar or the camshafts.  Do not use the bar to prevent rotation.   Use a proper sized open end wrench.
Loosening the Camshaft Sprockets Part 1
  • Due to slight variations in the the spacing between timing belt teeth, we must loosen but not remove the camshaft sprockets. The intake sprocket bolt is hidden inside of the VCT gear, and the cover must be removed to expose it.
  • There is a T55 Bolt holding the exhaust sprocket in place. While holding the camshaft with a proper open end wrench, loosen but do not remove this bolt. This will allow the camshaft sprocket to rotate.
  • It is reccommended that you remove the timing bar while loosening to avoid damage to the bar or the camshafts. Do not use the bar to prevent rotation. Use a proper sized open end wrench.
  • There is a T55 cap on the VCT gear. Unscrew it to expose the E18 bolt holding the exhaust camshaft sprocket in place with a proper open end wrench.
  • There is oil in this gear! Be prepared with a small container to catch it in. Clean all of the oil from the gear and ensure none gets on your crankshaft sprocket
Insérez ici votre traduction
