Aller au contenu principal
Anglais
Français
Traduction de l’étape 24
Étape 24
After all of the oil is drained, loosen the E18 bolt holding the intake sprocket in place while holding the camshaft with a proper open end wrench During reassembly this bolt will need to be torqued to 120 Nm During reassembly this bolt will need to be torqued to 37 Nm
Loosening the Crankshaft Sprockets Part 2
  • After all of the oil is drained, loosen the E18 bolt holding the intake sprocket in place while holding the camshaft with a proper open end wrench
  • During reassembly this bolt will need to be torqued to 120 Nm
  • During reassembly this bolt will need to be torqued to 37 Nm
  • During reassembly this bolt will need to be torqued to 68 Nm
  • With both sprockets loose, place the timing bar back into the camshafts to ensure they remain at TDC
Insérez ici votre traduction
