Aller au contenu principal
Anglais
Français
Traduction de l’étape 25
Étape 25
It is recommended that the tensioner and idler pulleys be changed at the same time as the timing belt. There is one 10mm bolt holding the tensioner pulley in place There is one 15mm bolt holding the idler pulley in place
Timing Belt Tensioner, Idler, and Belt Removal
  • It is recommended that the tensioner and idler pulleys be changed at the same time as the timing belt.
  • There is one 10mm bolt holding the tensioner pulley in place
  • There is one 15mm bolt holding the idler pulley in place
  • The belt should slide off
  • This is the hole where the tensioner pulley's tab should slide into on reassembly
  • With the timing belt off, you should be able to freely spin the camshaft sprockets without rotating the camshafts while the timing bar is in place
  • With the timing belt removed never rotate the crankshaft or camshafts independently of one another. Doing so could result in permanent engine damage
Insérez ici votre traduction
