Aller au contenu principal
Anglais
Français
Traduction de l’étape 26
Étape 26
After rotating the crankshaft clockwise until it no longer moves to ensure it has remained at TDC, and the timing bar is inserted on the camshafts to ensure that they remained at TDC, we can begin to install the new timing belt. Begin by installing the new tensioner, tightening the 10mm bolt until it is hand tight Ensure that the tab on the pulley has fallen into its proper slot
Timing Reassembly Part 1
  • After rotating the crankshaft clockwise until it no longer moves to ensure it has remained at TDC, and the timing bar is inserted on the camshafts to ensure that they remained at TDC, we can begin to install the new timing belt.
  • Begin by installing the new tensioner, tightening the 10mm bolt until it is hand tight
  • Ensure that the tab on the pulley has fallen into its proper slot
  • Ensure that the tensioner adjusting washer is in the 4 o'clock position
  • Install the new idler pulley, torquing the bolt to 25 Nm
Insérez ici votre traduction
