Aller au contenu principal
Anglais
Français
Traduction de l’étape 28
Étape 28
With the belt installed, insert a 6mm hex key into the tensioner adjusting washer Rotate the washer counterclockwise to tension the belt During this process the tension indicator will move clockwise
Timing Reassembly Part 3
  • With the belt installed, insert a 6mm hex key into the tensioner adjusting washer
  • Rotate the washer counterclockwise to tension the belt
  • During this process the tension indicator will move clockwise
  • Continue rotation until the tension indicator has reached the point where the mark on the tab is centered between the forks of the indicator
  • While preventing the tensoiner adjusting washer from moving, torque the 10mm bolt to 25 Nm
Insérez ici votre traduction
