Aller au contenu principal
Anglais
Français
Traduction de l’étape 32
Étape 32
Reassembly
  • Once you are convinced you engine is 100% in time, begin reassembly following proper torque specs starting on Step #18 and working backwards.
  • Failure to ensure your timing bar and pin do not line up nearly perfectly 100% of the time could result in permanent engine damage.
  • Start the car up and let it warm up. Take it for a test drive, briefly running the engine all the way through to its highest RPM
  • If you get DTCs P1381 or 1383, see the previous step for how to alleviate them. If you see poor performance or other DTCs, it may be that you did not carefully verify your engine was in time.
Insérez ici votre traduction
