Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
The clutch cover is constructed from aluminum and is held on to the clutch hinges with metal clips that require a good deal of force to remove. Proceed with caution. Use your thumbs to push the clutch cover away from the clutch hinges.
  • The clutch cover is constructed from aluminum and is held on to the clutch hinges with metal clips that require a good deal of force to remove. Proceed with caution.
  • Use your thumbs to push the clutch cover away from the clutch hinges.
  • While pressing with your thumbs, rotate the clutch cover toward yourself about its long edge to pop it off the clutch hinge.
  • It may be necessary to wiggle the clutch cover while pressing it away from the clutch hinges to release the retaining clips.
Insérez ici votre traduction
