Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Lift the case from the bottom side. NOT the side with the hinges. When you feel resistance, do NOT keep lifting or you will damage the housing. Once you feel resistance, gently pull the case towards you. (away from the hinges.)
  • Lift the case from the bottom side. NOT the side with the hinges.
  • When you feel resistance, do NOT keep lifting or you will damage the housing.
  • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
  • Remove the case.
Insérez ici votre traduction
