Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 2
Étape 2
Tuck one end of the ribbon into the pocket, inserting the ribbon past the missing seam. If you are are using a ribbon that has an obvious front and back, insert the ribbon so that the back is facing out.
  • Tuck one end of the ribbon into the pocket, inserting the ribbon past the missing seam.
  • If you are are using a ribbon that has an obvious front and back, insert the ribbon so that the back is facing out.
Insérez l’extrémité du ruban à l’intérieur de la coulisse.
Si l’envers et l’endroit du ruban sont différents, insérez celui-ci de manière que l’envers soit visible.
