Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Anglais
Français
Traduction de l’étape 10
Étape 10
Use a flat blade screwdriver to separate the two halves of the boiler. Inside the boiler, you can see the main components: Boiler housing (to contain water and steam).
  • Use a flat blade screwdriver to separate the two halves of the boiler. Inside the boiler, you can see the main components:
  • Boiler housing (to contain water and steam).
  • Heater coil.
  • Dual thermal sensors, presumably one to maintain steam temperature and one for max temperature shut down.
  • The bottom portion of the boiler housing has a rigid hose reaching toward the top of the boiler to draw water from the top to keep the heater coil immersed in water.
  • There are also two Klixon thermal sensors. The numbers stamped around their bases are:
  • 1NT01L-0036 L95-10 9910 M 10/250~T200
  • 1NT01L-0499 L127-15 9912 M 10/250~T200
Insérez ici votre traduction
