Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise. The two screws above the screen assembly are deep so you may need a long screwdriver. The two screws above the screen assembly are deep so you may need a long screwdriver.
  • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
  • The two screws above the screen assembly are deep so you may need a long screwdriver.
Insérez ici votre traduction
